Speedfan.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/279691-control/#findComment-3796934
Yep speedfan if your motherboard supports controlling the fan speed, otherwise you're pretty much stumped. There are some fan controllers out there which connect by usb internally, but honestly for the price of those, you could just get a new motherboard which supports it like an MSI 970 gaming (Off the top of my head as one which supports fan control in software)
Cartman - AMD Phenom II x6 1055T 3.1Ghz - 10GB Ram (Mwahahah) - 256GB Crucial MX100 Boot - 2TB WD Red - Gainward GTX 770 - Zalman Insanely Loud CNPS14X - Corsair 230T Orange
Stan - Intel Pentium G3320 - 8GB Ram - 128GB Intel 520 - Raid 1 6TB WD Reds - Bit Fenix Prodigy
Kenny - HP 14 Ultrabook (No name apperently) i3 4130 - 128GB Intel 520
https://linustechtips.com/topic/279691-control/#findComment-3798719
