This is a bit of an interesting issue.  I sent my Acer S7-392 off to Acer for a battery problem (not knowing at the time that it was user replaceable /derp/), and when I got it back I did an OS reinstall because it was due anyway.  Now that I have reinstalled EVERYTHING I can think of, including all of the runtimes, Google Chrome will not register a click on a button to change an option.  It shows the hand with the index finger, and the link address at the bottom left of the page changes, but when clicked, it doesn't do anything.  The site(s) work just fine in IE and FF but not in Chrome.  The number one site it has been particularly annoying on is www.acura.com.  If you click MDX at the top of the page and then try to select different options, they will not change in chrome.
The above description may contain run on sentences and heavy confusion, but it is late and I'm frustrated. :)
https://linustechtips.com/topic/279526-chrome-buttons-not-clickable-issue/
Chrome issues are incredibly frustrating so I feel ya.
Try completely uninstalling chrome and then reinstall. I put emphasis on COMPLETELY b/c chrome leaves a lot of traces on your pc after uninstalling which cause problems to persist after a reinstall. Make sure to delete the directories in C:\program files x86 as well as uninstall "Google Update" (another program that is sometimes installed along with it) and also delete an extra folder for chrome that is stored in C:\users\"Your Name"\app data\ google (Do note that app data is a hidden folder so to view it head to folder options > view > show hidden files, folders in the windows explorer)  then run a registry cleaner (ccleaner is good) and also reboot the pc b4 reinstall.
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Quisque euismod suscipit est, non placerat turpis vestibulum sed. Phasellus et faucibus odio. Donec a nisi at purus porttitor ullamcorper auctor a nibh. Integer id neque a nisi laoreet ultrices id ac augue. Nulla facilisi. Nullam purus elit, dictum quis euismod vitae, mollis non dui. Morbi vehicula neque eu mattis bibendum. Curabitur sed odio tortor. Sed euismod mi in diam volutpat, vitae convallis ipsum mattis. Praesent eleifend faucibus pulvinar. Interdum et malesuada fames ac ante ipsum primis in faucibus. Vestibulum velit nunc, fermentum a libero a, venenatis tempus lectus.
I used chrome for a long time, then crap like this happens and it would aways crash randomly so i just switched to firefox....havent had any of those problems at all since.
Main Rig: | CPU: Intel Core i9-7900x | GPU: Nvidia RTX 2080 Founders | Mobo: Asus ROG Strix X299-E Gaming | RAM: 32GB Corsair Vengeance LPX DDR4 3000 MHz | SSD: Samsung 980 Pro w/Heatsink 1TB & Samsung 960 Pro 1TB | Sound: Parasound ZDAC & Burson Soloist Amp | PSU: Corsair RM850 | Fans: 2x Noctua NF-F12 | Case: Caselabs MAGNUM SMA8 | Headphones: Sennheiser HD 800 | Keyboard: WASD V3 | Mouse: Logitech G502 Lightspeed | Mousepad: Logitech G PowerPlay | CPU Cooler: bequiet! Dark Rock Pro 3 | Primary Monitor: Acer Predator XB272 | Extra Monitors: Samsung Syncmaster PX2370 |
I tried Mujteba's solution but it didn't work.  It still did the same thing after the reinstall.  I don't have the problem on other computers with chrome, just on this one.  I would switch to firefox, but the account integration with google across all 4 of my computers make chrome the obvious choice.
