Triple Monitor cable configuration - MSI GTX 970
Solved by Mick Naughty,
You should be able to do that, as long as its a decent adapter/cable. I believe that amd card can only support 3 monitors using the correct ports, either hdmi or dp. I don't think both can be used.
Featured Topics
DahPython ·
Posted in CPUs, Motherboards, and Memory2 -
1
1
pilgr1mag3 ·
Posted in Graphics Cards5 -
Oygevalt ·
Posted in Graphics Cards7 -
SircarrotII ·
Posted in Programs, Apps and Websites2
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
