a X99 compatible CPU
a SSD
a HDD
a GPU
a PSU
some X99 compatible RAM
then you should be good to go
Honestly if you only know the X99 name, don't get a freakin X99 system, it is for enthusiasts!!!
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/279195-x99-help-pls/#findComment-3788819
please give me a list of parts to go with a x99 board and cpu budget is like 2500 usd
without perhipherils
country ? windows licence ? parts you allredy have ?
pc size ? (Mitx/Matx/ATX)
https://linustechtips.com/topic/279195-x99-help-pls/#findComment-3788940
a SSD
a HDD
a GPU
a PSU
who said thats the only thing i know about the x99 chipset?
https://linustechtips.com/topic/279195-x99-help-pls/#findComment-3795084
@REXOR456 just that pc box ?
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($299.99 @ Micro Center)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($123.99 @ SuperBiiz)
Motherboard: Asus X99-DELUXE ATX LGA2011-3 Motherboard  ($372.95 @ SuperBiiz)
Memory: A-Data XPG Z1 32GB (4 x 8GB) DDR4-2133 Memory  ($494.99 @ Amazon)
Storage: A-Data Premier SP610 512GB 2.5" Solid State Drive  ($209.99 @ Amazon)
Storage: Seagate  2TB 3.5" 7200RPM Internal Hard Drive  ($92.24 @ NCIX US)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card (2-Way SLI)  ($339.99 @ B&H)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($99.99 @ NCIX US)
Total: $2489.11
Generated by PCPartPicker 2014-12-29 03:46 EST-0500
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/279195-x99-help-pls/#findComment-3796033
yep i have all that
you didn't even answer my ... uh whatever
https://linustechtips.com/topic/279195-x99-help-pls/#findComment-3799421
