My pc componets at the moment :
Processor Intel® Core2 Duo CPU E8200 @ 2.66GHz Manufacturer Intel Speed 2.7 GHz Number of Cores 2 CPU ID BFEBFBFF00010676 Family 06 Model 17 Stepping 6 Revision 0C
Video Card AMD Radeon HD 7700 Series Manufacturer ATI Chipset AMD Radeon HD 7700 Series Dedicated Memory 1.0 GB Total Memory 2.2 GB Pixel Shader Version 5.0 Vertex Shader Version 5.0 Hardware T & L Yes Vendor ID 1002 Device ID 665C Plug and Play ID VEN_1002&DEV_665C&SUBSYS_22691458&REV_00 Driver Version 12.101.2.0
Memory 3.5GB (it 2x2 Gb Crusial DDR2 800)
Operating System Microsoft Windows 7 Professional Edition Service Pack 1 (build 7601), 32-bit Service Pack 1 Size 32 Bit Edition Professional
Motherboard: Asus P5Ql
I want to upgrade my motherboard, ram ,and cpu.
I would like a AMD cpu.
My budged is 400 $
Can somebody recomand me something with ddr3 memory ofcorse?
It for my gaming rig!
Thanks in advance . :)
https://linustechtips.com/topic/279168-upgreading-my-pc-help/
Something like a 8320 or an 8350 with some cheaper 990fx board, and 8gb of DDR3 vengeance or ripjaws 1333 or 1600 mhz would work great for you.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/279168-upgreading-my-pc-help/#findComment-3788143
