So I've been playing The Crew for some time and there are some problems I was able to work around for some time as long as the game decided to play nice. The main problem is that every time I connect to game, it drops windows microphone volume down to 50%. It happens every time I start up the game or it loses the connection and have to reconnect. I've tried everything I found on the internet - running as admin game executables, disabling uplay voice chat, setting sound communications thingy to 'do nothing' in control panel, but none of that has worked. Temporary solution to this is alt tab out of the game, turn back the mic volume to 100% and play, but yesterday it got even better. I mostly use mumble for communications, but had to go on teamspeak when I noticed that friends are ignoring me. Turns out that the game somehow was disabling my push-to-talk. Put it to voice activation and it worked great. Is there someone with similar problems and/or has solved them?
TL;DR
The Crew:
  • on startup/lost connection turns down mic volume in windows to 50%
  • disables teamspeak push-to-talk
  • using windows 8.1, asus z97-a onboard audio and creative fatal1ty headset
  • help?
https://linustechtips.com/topic/279052-the-crew-and-microphone-problems/
I have the same thing happen its very odd.
Rig CPU Intel i5 3570K at 4.2 GHz - MB MSI Z77A-GD55 - RAM Kingston 8GB 1600 mhz - GPU XFX 7870 Double D - Keyboard Logitech G710+
Case Corsair 600T - Storage Intel 330 120GB, WD Blue 1TB - CPU Cooler Noctua NH-D14 - Displays Dell U2312HM, Asus VS228, Acer AL1715
