PC Build for 2015.
Solved by WoodenMarker,
Bottom line , upgrade GPU ( and maybe cooler and case for a quieter experience?) as long as a new monitor , and wait out for the next gen CPU's?
Cases are inherently silent. As long as you don't dislike your current case, I'd suggest just replacing the fans--same goes for your cooler.
Would you be striving for as quiet of a system as possible or just relatively quiet?
As for the monitor, upgrading it could be a great idea. I'd personally wait for 4K to become more affordable if you don't mind sticking with your current display for a bit longer.
Upgrade from your 2600 when you need to and not just when it's 'getting old'.
