my motherboard is the asrock 1155 Z75 PRO3.
  • Memory: 4x DDR3 2800+(OC)/2400(OC)/2133(OC)/1866(OC)/1600/1333/1066 DIMM Slots, Non-ECC, Unbuffered, Dual Channel, Max Capacity up to 32gb
can i use this set: http://www.amazon.com/gp/product/B004CRSM4I/ref=ox_sc_act_title_7?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
thanks, Mike
[ I7-4770K ][ Gigabyte GA-Z87-UD3H ][ Corsair Dominator Platinum 16gb ][ Corsair Carbide 300R ][ Corsair HX850 ][ Gigabyte Gtx 770 ]
[ Samsung 840 Series 500gb SSD ][ Bitfenix Spectre Pro (Blue LED) + Bitfenix Recon Fan Controller ]
https://linustechtips.com/topic/27883-buffered-memory-help/
That will work great! Put one stick in the 1st slot and the other in the third slot, this will give you optimal performance.
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
https://linustechtips.com/topic/27883-buffered-memory-help/#findComment-354412
thank you. fishymaba
https://linustechtips.com/topic/27883-buffered-memory-help/#findComment-354614
