Hi
I have a few questions I'd like to iron out before committing to this build of mine.
Motherboard Gigabyte Z97X-UD3H Motherboard
CPU Intel Core i5 4690K
GPU Gigabyte GeForce GTX 970 G1 Gaming 4GB
RAM G.Skill Ares/Sniper DDR3-2133
CASE Fractal Design ARC XL or Define R5
PSU Seasonic G-650 80Plus Gold 650W (may change if I decide to go SLI)
COOLER Noctua NH-D15 CPU Cooler
HDD Samsung 840 EVO Series 250GB SSD and Seagate Barracuda 2TB ST2000DM001
With the parts the I've chosen, is it better to have a low profile ram with the NH-D15 or can I have G.Skill Snipers.
Along with that is the problem deciding the case, as I'm not too sure if there will be enough clearance inside the Define R5 with high profile ram and a massive air cooler like the NH-D15.
https://linustechtips.com/topic/278788-need-advice-on-first-build/
You really only need DDR3-1600.
PCPartPicker Part List: https://pcpartpicker.com/list/THNVZf
CPU: Intel Core i5-8600K 3.6 GHz 6-Core Processor  ($244.00 @ B&H)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($89.95 @ Amazon)
Motherboard: Asus ROG STRIX Z370-F GAMING ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($84.99 @ Best Buy)
Storage: ADATA XPG SX6000 Pro 256 GB M.2-2280 NVME Solid State Drive  ($51.99 @ Amazon)
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive  ($164.00 @ Amazon)
Video Card: Zotac GeForce GTX 1080 8 GB AMP! Extreme Video Card
Case: Fractal Design Define C TG ATX Mid Tower Case  ($104.98 @ Newegg)
Power Supply: Rosewill 650 W 80+ Gold Certified Fully Modular ATX Power Supply
Operating System: Microsoft Windows 10 Pro OEM 64-bit  ($139.99 @ Other World Computing)
Monitor: LG 32GK650F-B 32.0" 2560x1440 144 Hz Monitor  ($396.99 @ B&H)
Total: $1276.89
Generated by PCPartPicker 2020-04-12 03:07 EDT-0400
The s12g-650 is already plenty for sli.
Sniper ram isn't that tall. It fits just fine.
What's the system being used for?
It's purely for gaming, maybe with the thought of going 2 1440p monitors in the future.
I thought the G.Skill Sniper was slightly tall so that would mean I'd need to move the fan up on the NH-D15.
Well if that's the case then all should be fine then, and thanks for the replies.
g skill sniper is low profile so it should be fine
It's not low profile being 42mm tall. Standard ram height is 30-35mm.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
