Hey guys, so i have a Yamaha audio receiver that i bought off craigslist and it works great. the only complaint i have about this is that whenever i turn it on, the volume level defaults to +16 db....which can get pretty annoying causing me to have to turn it down everytime i want to use it. Does anybody know a way in which i can lower the default volume level? Thanks :)
Oh and by the way the model is the Yamaha Natural Sound A/V receiver RX-V361
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
https://linustechtips.com/topic/278675-av-receiver-help/
Go to page 43 of your manual, which will show you how to get into your audio settings. Then go to 48 which shows you how to set your initial volume.
Something like
MENU> G)AUDIO SET> INITIAL VOLUME
And change from 16 dB to 4 or w.e you want.
Good luck, hope thats the ticket
Current System Specs:
MOBO: Gigabyte Aorus Ultra Gaming     CPU: Intel i5 9600k      GPU: EVGA GTX 1070 ti FTW Ultra Silent    PSU: EVGA 750 G2 80+ gold
Ram:  16GB Corsair Vengeance RGB Pro DDR4-3200    Storage: 500 GB Samsung 970 EVO/ 4TB WD Blue Case: Corsair 275R-White
https://linustechtips.com/topic/278675-av-receiver-help/#findComment-3780619
