Hello, I want to do a 900 dolla build with windows and needed some help. Should I go with like a 290 or what
Specs: Intel i7-4790k | Corsair H60 | Asrock Z97 Pro4 | 4x4g Corsair Vengeance | Gigabyte g1 970 | Sandisk u110 128GB SSD | 1TB Toshiba Hard Drive | Corsair RM750 | Corsair Air 540 4 Corsair AF120 LED Purple 2 Corsair AF140 LED Purple
https://linustechtips.com/topic/277888-help-with-build/
https://linustechtips.com/topic/277888-help-with-build/#findComment-3769246
Thats over 900 doe
Nope, $885 if you use all retailers, you need to specify if you can't use any, you also need to specify a country if it isn't the usa.
https://linustechtips.com/topic/277888-help-with-build/#findComment-3769252
Well, the Micro Center CPU is going to bring it up by like $30 if he doesn't live near a Micro Center. Plus you have windows as purchased at $0.00.
https://linustechtips.com/topic/277888-help-with-build/#findComment-3769266
The cpu isn't marked as from microcenter for me. I didn't see that it needed to include windows. This is my updated build http://pcpartpicker.com/p/Vd6mRB
https://linustechtips.com/topic/277888-help-with-build/#findComment-3769303
