They are as you expect them to be. There really isn't a worry unless you're entering the 100+ C range in Prime95/Aida64 etc.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/277705-are-these-temps-okay/#findComment-3767343
Perfectly fine considering you'll likely never reach those temperatures during everyday tasks.
https://linustechtips.com/topic/277705-are-these-temps-okay/#findComment-3767358
