Hey guys!  :)
This is going to be my first build, and only for gaming.
Mobo - ASUS Maximus VII Hero
CPU - i5-4690K 3.5 Ghz - for cooling i chose Corsair Hydro 110
GPU - ASUS Strix GTX 970
RAM - Corsair Vengeance Pro 8GB DDR3 2133Mhz CL9
SSD - Samsung 850 Pro 256GB
HDD - Seagate Barracuda 2TB 7200Rpm
Case - Corsair Graphite 760t
PSU - Corsair RM 650w
Let me now guys, what do u think about this setup?
Happy Holydays!  ;)
https://linustechtips.com/topic/277486-my-first-build/
Change the PSU to evga's 80+ gold and i'll take that set up over mine anyday :P
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/277486-my-first-build/#findComment-3765065
Well what kind of power hungry hardware? I don't have any plans for sli for example.
Well if you are not gonna SLI then 500-600W would be enough as intel and nVidia are both pretty power efficient. with a TDP of 225W and 88W for the I5 with the rest being redudant a 500-600W PSU would be fine. Still what is the price of a EVGA G2 750W compared to the Corsair RM 650W?
https://linustechtips.com/topic/277486-my-first-build/#findComment-3765299
Well the EVGA is 38,200 HUF https://ipon.hu/webshop/product/evga_supernova_g2_750w/743915
and the RM is 37,500 HUF https://ipon.hu/webshop/product/corsair_rm_series_650w/514877
so there is not much difference in the pricing... it is around 5$
Should i go with the EVGA? But i wonder will the system (or the psu) take 750W? Or just take the amount that the system requires (the amount that you mentioned -> 225 for the gpu 88 for the cpu and the other stuff is minimal or at least much lower, right)?
https://linustechtips.com/topic/277486-my-first-build/#findComment-3765539
