Hey all, I was wondering if I was to convert an mpeg audio file (320kbps) to an AAC file (128kbps) on iTunes, would the sound quality be affected? The sound files are kinda big and I wanna save space on my phone, converting them to AAC reduces them in file size.
If I want the best sound, would they need to be mpeg audio file or does it not matter?
Thanks in advance,
Sean.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/276986-itunes-conversion/
I guess it depends what you're listening to/ what you're using for your listening. Just, try it and see if you notice a difference, surely it should take too long to do 1 conversion and do a side by side listening test.
https://linustechtips.com/topic/276986-itunes-conversion/#findComment-3759268
