hello, i am using the sapphire trixx software to oc my r9 280x tri x gpu. i got to 1250 mhz core clock and 1650 memory clock while idleing at 60 degrees Celcius. when i push any further, myh screen goes black for 2 seconds then the image comes back with the game/ benchamrk crashing. then it tells me my display drivers crashed and recovered. does this mean i hit the ceiling on my oc or is there a driver issue?
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/276495-r9-280x-oc-issue/
Sounds like you hit the OC wall.  Back up about 5 Mhz at a time on both core and memory. Then run bench each time you back off....then increase if stable.  Check voltage as ForsakenLive suggested as well once you hit a stable OC.  Trial and error...good luck.
Case: Silverstone SG09B Motherboard: MSI Z10 Morter M-ATX CPU: I5-6600K  Ram: Corsair LP 2400 DD4 16GB GPU: MSI RX 480 Storage: Seagate HDD Baracuda 2TB x2, Crucial M200 500GB SSD X2 (Raid 0)PSU: Silverstone Strider Gold 1000W w/PP05E Kit
"When to say :blink: WTF :blink: ....$2K rig only used for Minesweeper and Internet Checkers marathons...."
https://linustechtips.com/topic/276495-r9-280x-oc-issue/#findComment-3753903
