CPU running too hot
By
KermitFTW
in Troubleshooting
in Troubleshooting
Solved by vlkn´,
change the pump settings and fans speeds if you can. And don´t leave it on "silent mode" or something like that.
Bubbles in the liquid and substances that block your heatfins in the radiator/cpu cooler can lead to less "cooling performance".
If after changing the speed settings, the temperatures aren´t lower than before. I´ll recommend you to rma the cooler.
YoungBlade ·
Posted in CPUs, Motherboards, and Memory7 -
derekchan ·
Posted in New Builds and Planning6 -
5
4
6
kerriya ·
Posted in Cases and Mods9 -
octester ·
Posted in Troubleshooting8
play_circle_filled
Latest From ShortCircuit:
