Is it better to use one or two cables to power my graphics card?
Solved by Faa,
Well by default the OCP is set to 30Amps per PCIe cable, you can raise this to 40Amps or turn the limitation completely off. There are no cards atm other than the 295x2 that draws more than 40Amps, the 295x2 is at 45Amps. 45Amps is farrrrr from enough to burn a cable. So no it doesn't make any difference and your 980's each hardly take more than 10Amps.
Featured Topics
Flashmatrix ·
Posted in Storage Devices3 -
Nixx23 ·
Posted in Storage Devices0 -
Witchandglad ·
Posted in Phones and Tablets1 -
ElChales ·
Posted in CPUs, Motherboards, and Memory2 -
Steve Chan ·
Posted in LMG Sponsor Discussion2 -
