if I use the mobo ports to plug in my monitor, will it make my GPU useless and ONLY use the iGPU?
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/275375-using-mobo-io-vs-gpu-io/
Yes, most of the time they won't even work.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/275375-using-mobo-io-vs-gpu-io/#findComment-3739482
Yes!
It'll make your GPU useless.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/275375-using-mobo-io-vs-gpu-io/#findComment-3739496
depends. AMD cards will give the iGPU a piggyback ride - so to speak - if you enable iGPU multi-monitor in bios and plug a monitor into motherboard.
I believe with Nvidia this is not the case.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/275375-using-mobo-io-vs-gpu-io/#findComment-3741757
