Whats the best cooler under 150mm tall, without breaking the bank? Looking for a better cooler for my Q6600 in a Fractal Design Core 1000.
Seems a Hyper 212 is just too big, so anything with similar price/cooling that is a bit shorter would be perfect. Any suggestions? I might just get a 212 and drill holes where the heatpipes are.
3770K | GTX970 | 16GB DDR3 | Corsair RM750
https://linustechtips.com/topic/27495-decent-low-profileish-cooler/
Cant seem to find the GeminII S524 in the UK, and the M4 doesnt seem to perform that well.
I would go with a h80 or something but i dont fancy mounting it on my side panel, which is the only 120mm space.
This might be one to think about.  142mm
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118019
Has a 5 egg rating on newegg and over 2200 reviews
You could also look at something like the Noctua NH C14 at 130mm if you are not opposed to that style of cooler.  I have one currently and it does a good job
Then there is also the Noctua NH U12P at 125mm
I would go for a blow down cooler like the noctua c-14 or the phanteks version of it.
