Hello everyone i figured that since some of you might know a bit about tv's you might be able assit me in my little delema.
The set up; I have my gaming rig, with a 670 GPU which has four ports, 2 dvi, 1 hdmi, and 1 DP. I have my destop running three monitors, not a problem.
But im a big gamer and i grew up with my PS2 and Gamecube. So i bought myself a simple 40in tv to game on, but i figured why not use my desktop with steam big picture to play all my lovely looking PC games with my wireless gamepad.
First solution to my problem did not work, i got a dvi splitter to mirrow my main monitor where games show be default to my tv. Seemed simple enough, but because the tv does not create a load while it is off the ditial signal creates a strange feedback that messes the image on my desktop main monitor.(The plitter was an active cable)
So i decided to get a DP to HDMI cable so i could use the 4th port on my gpu thinking that when i disconnect monitors while my computer is on doesnt freak things out. I set up though windows for it to be copy of my desktop. This works perfectly when the tv is on (along with my pc), if i were to turn the tv off still every thing is just the way i had set it up prior' everything working. But when i turn the tv back on it get this strange bug. It copies the image to the tv just as it had before but my mouse freaks the fuck out: Image of the mouse and movement is change 90 degrees from what i do and only on the main. It works perfectly on the sides monitors, just until to move it over to the main.
anyone else setting up systems to their tvs have this problem?
Thx
Work Station:: Cooler Master Storm Trooper // i7-3930K @ 3.9 GHz // Asus Sabertooth X79 // Corsair Vengeance 16GB (4X4GB) 1600 MHz // Cooler Master 1200W Gold // Xonar Essence STX // Radeon HD 6970 // Avermedia HD Live Gamer Pro
Gaming Rig:: Cooler Master Scout // i7-2700k @ 4.0GHz // MSI Z68 // G-Skill Ripjaw 16GB (4X4EB) 1066MHz // Antec 750W Bronze // Creative Sound Blaster X-Fi HD // EVGA GTX 670
https://linustechtips.com/topic/27482-problem-maybe-you-can-help/
If your mouse is behaving strangely, it's probably either your graphics drivers or your mouse drivers that is acting up.
Which drivers do you got installed for your graphicscard and what mouse do you own (and what drivers are you using for it)?
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
https://linustechtips.com/topic/27482-problem-maybe-you-can-help/#findComment-349399
<p>I had though that might bew an issue, but i did a windows update, then got the lasted nvidia drive aswell with the latest driver for my R.A.T 7 mouse, still has the same issue.</p>
<p> </p>
<p> </p>
<p>mouse is using 7.0.20.0 from Mad Catz Inc</p>
<p>gtx 670  9.18.13.2018</p>
Edited by Agons
https://linustechtips.com/topic/27482-problem-maybe-you-can-help/#findComment-349708
