CPU Cleaning
Go to solution Solved by Akolyte,
Yeah, I used it on my CPU.  Just use it with a coffee filter.  And it dries really quick, so after its dried put the new cooler on.
Should be fine.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/274760-cpu-cleaning/#findComment-3730541
He means wipe the old paste off with the filter instead of paper towel. The filter will not leave behind fibers.
My Build | CPU: Intel Core i7-6700K 4.0GHz Quad-Core | CPU Cooler: Corsair H100i | Motherboard: Asus SABERTOOTH Z170 S ATX LGA1151  | Memory: Crucial Ballistix Sport 16GB DDR4-2400 Memory | Storage: Samsung 850 EVO-Series 120GB & 250GB, Western Digital Caviar Blue 1TB 3.5" 7200RPM, HGST Deskstar NAS 3TB 7200RPM | Video Card: MSI GeForce GTX 970 4GB 100 Million Edition | Case: NZXT H440 (Black/Green) | Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified | OS: Microsoft Windows 10 Pro (64-bit)
https://linustechtips.com/topic/274760-cpu-cleaning/#findComment-3730621
