Water vs Air cooling?
Go to solution Solved by WoodenMarker,
Air cooling has less points of failure and is usually cheaper/quieter. Watercooling can perform better at the higher end. They both have their advantages and disadvantages.
By water cooling i mean AIO but is it safe or is air cooling better?
CPU: Intel Core i7 4790K
CPU Cooler: Noctua NH-D15
RAM: Corsair Vengeance Pro 16GB 1866MHz
GPU: Asus Strix RTX 2060 OC
Motherboard: Asus Maximus VII Hero
Storage: 1TB, 500GB, 250GB SSD's, 1TB SSHD
Case: Corsair Carbide Air 540
https://linustechtips.com/topic/273612-water-vs-air-cooling/
https://linustechtips.com/topic/273612-water-vs-air-cooling/#findComment-3716160
Air cooling the only point of failure is the fans, AIO has many point of failure (pump, leaks, etc...).
Air cooling will be much quieter under stock configuration (without replacing fans) like NH-D14/15
Top end AIO will be better than air cooler in terms of cooling potential.
Yeah, we're all just a bunch of idiots experiencing nothing more than the placebo effect.
https://linustechtips.com/topic/273612-water-vs-air-cooling/#findComment-3716167
Well im looking at some of Corsairs AIOs. Any other specific brands that are better?
https://linustechtips.com/topic/273612-water-vs-air-cooling/#findComment-3716172
Swiftech H220x/H240x, Cooler Master Glacer / Nepton 280L (with aftermarket fans), Water 3.0 Ultimate 360mm rad
https://linustechtips.com/topic/273612-water-vs-air-cooling/#findComment-3716182
Thank you i will look into them! :)
https://linustechtips.com/topic/273612-water-vs-air-cooling/#findComment-3716188
Going for the CM Nepton 280L! Thanks guys :)
https://linustechtips.com/topic/273612-water-vs-air-cooling/#findComment-3716288
@Faceman would be proud.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/273612-water-vs-air-cooling/#findComment-3719490
