Geforce & Radeon on SAME PC?
Go to solution Solved by QueenDemetria,
You can do it, just install the card and the nvidia drivers. I have a 550 ti and 270X in my workstation and they work together just fine. You will either have to switch the video cable each time you want to switch cards or plug both cards into your monitor(and switch in windows). If you buy a KVM or video switch, you can switch between your cards in windows while only taking up one port on your monitor.
Hi, I currently have a perfectly running PC,
AMD 8350
Radeon HD 6990
etc etc.
however As the Radeon HD 6990 takes too much power, I was thinking of disabling it, and only using it when I need to run heavy games.
The idea was to add a Geforce 510 which I have lying around, from an old Media PC.
Video streaming, browsing etc could be done by the 510.
So the question is.
Will it work? Linus has done Crossfire AND SLI on the same PC before. I'm just wondering about driver issues, as i hear many people doing a "clean" install of windows, when they switch between Nvidia and AMD graphics cards.
-The way I want to select the card to use, is by having one of them connected to the screen by HDMI, the other DVI.
Thus primarily HDMi (510), and have the HD 6990 disabled from device manager (to turn it off?)
Any ideas?
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
https://linustechtips.com/topic/273330-geforce-radeon-on-same-pc/
For me it works fine with my 7950 and 480.
EDIT: To switch between them, I found it works to move all monitors to the card you want to use, reboot (sometimes) and then it will be fine.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
I think ti could work but it might cause problems in games were you can't select your video adapter. Mostly i see the use for this being one card for gaming and the other for folding or something.
what i say is have the install .exe driver for both nvidia and amd drivers, then also get DDU (http://www.guru3d.com/files-details/display-driver-uninstaller-download.html) so you uninstall the driver using DDU, and then just run the driver install file and rinse and repeat
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
disable X-fire and turn the GPU core speed down + power limit down in afterburner when you're browsing etc, turn it back on when gaming.
"Move all monitors to the card???" What?  - Okay I'm using ONE monitor :-D You mean just switching Between the cable input to the monitor?
How it will be.
1. HDMI is attached to 510
2. DVI is attached to 6990
Then I'll just switch on screen, input signal?
Just buy a GTX 970.
i7 5930k . 16GB Corsair Vengeance LPX 2666 DDR4 . Gigabyte GA-X99-Gaming G1-WIFI . Zotac GeForce GTX 980 AMP! 4GB SLi . Crucial M550 1TB SSD . LG BD . Fractal Design Define R2 Black Pearl . SuperFlower Leadex Gold 750w . BenQ GW2765HT 2560x1440 . CM Storm QF TK MX Blue . SteelSeries Rival
i5 2500k/ EVGA Z68SLi/ FX 8320/ Phenom II B55 x4/ MSI 790FX-GD70/ G.skill Ripjaws X 1600 8GB kit/ Geil Black Dragon 1600 4GB kit/ Sapphire Ref R9 290/ XFX DD GHOST 7770
Whoaa xD I'm not much for playing with "clocking". Sorry, newbie here :-D
Easier for me to switch between screen input signal DVI/HDMI, then disable/enable the card from Device manager if possible.
You can do it, just install the card and the nvidia drivers. I have a 550 ti and 270X in my workstation then they work together just fine. You will either have to switch the video cable each time you want to switch cards or plug both cards into your monitor(and switch in windows). If you buy a KVM or video switch, you can switch between your cards in windows whilee only taking up one port on your monitor.
I do have 2 ports on my monitor. As I mentioned above, one DVI and one HDMI, which i can switch between on demand. Will this work? Connecting the cards to the different cables :-D
-Will disabling the card in device manager power it down?
You can switch between the two cards by using the "Screen Resolution" menu in the control panel(or right clicking on your desktop). If the card isn't set as a display it will turn off(well, go in to a very low power mode).
Just buy a GTX 970.
They cost like 2.400 DKK here, cheapest.
that's close to 400 $. I don't have that currently.
I bought the 6990 1½ years ago, for about 250$. -Still waaaay enjoying it :-D
But it's just waste of card life and power, to have it idling on browsing with temps:
GPU 1: 61'C - Due to browsing for some reason. IE, Chrome, Firefox all increase the gpu temp by 10-15 'C
GPU 2: 46'C
So again, Would if i could :D But enjoying the RAW MUSCLE
Wow, I really want to try this now :-D Thanks for the support!
Clocking down can NEVER hurt, well... okay... it hurts the power supplier because you use less :D
It does not power the card down, as that's simply not a software/driver-level thing: it turns on as soon as you touch your power button, it will stay on until your whole system is off.
Not using it like you propose does lower its power usage though. Simply because it doesn't have to send a refresh to the monitor 60 times/second
NICE! Thanks for that link! So with this I can clean my windows off of all the driver leftovers I might have from using different graphics cards? :-D (currently freshly installed for 6990 only)
Well :-D I can see what you mean. What happens if you clock it down TOO much? like 100MHz or less?? It's 830-880 Normally.
-Really wondering how much of a difference in power usage it will do, with no screen output. - Still might be worth it because one of the GPU's is constantly on 61'C and the other on 47'C except when gaming. which is a waste imo, I don't want one of them to die before the other :'(
But as the others mention, you could switch between the inputs to make the card you are about to use, the primary? :-D Then disable the other? :-D
presicely
TO ALL..
I mean, playing RUNESCAPE and browsing facebook+9gag which i do some hours a day, is REALLY a waste for the poor 6990. Runescape will not do Crossfire of course. Forced it on OpenGL, got very glitchy and caused much more load on BOTH GPU's instead of sharing the load. - So while playing other games than CS:GO, Shadow of Mordor, Crysis 2+3, X3 Albion Prelude, Grid 2, I really don't need to waste the 6990.
I would get shot  by SOME people because of this, So I'm trying to do something about it :D
I don't know how to disable/enable the cards, but you should be able to run then both without problems. I currently own a gtx 970 as the main card and an HD 6670 at once. Both being used for Folding at the same time, all I needed was to install the drivers, nothing else.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
How it will be.
Yeah. Just which card the monitor is attatched to.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
I'm trying this now. I just added the Zotac 510, installing the driver now :D
I can confirm that this is working on Windows.
Let's see how it works in games :-D  - Testing Dead Rising 3
Confirmed on both CS : GO and Dead Rising 3, switching works perfectly.
So I just have to switch before going into the game I'm about to play :-D
