It looks weird, but what exactly are you going to use it for?
Edit: Also, do you already have any parts, and what is your budget?
CPU i7-9700K @ 5 GHz Motherboard ASUS ROG Strix Z390-F RAM Corsair Vengeance 32 GB (4x8) 3000 MHz GPU ASUS RTX 2080 ROG Strix OC x2 SLI Case Corsair Graphite 780T Storage 256 GB Samsung 860 EVO, 6 TB Seagate Barracuda PSU Corsair HX1200i, 1200W Display(s) ASUS PG279Q (1440p 165 Hz), ASUS VG248QE (1080p 144 Hz) Cooling ASUS ROG Ryujin 360 radiator Keyboard Logitech G710+ Mouse Logitech G502 Sound Logitech G35 Operating System Windows 10
https://linustechtips.com/topic/272015-build-help/#findComment-3690194
I have the ram, 1 gpu and the Storage. I am also taking the CPU and the other GPU from another pc.
I would like to put as little as possible into it. I have about 200 dollars to add.
I will use it for GFX(photoshop,illustrator,cinema4d) and a bit of gaming(mostly CSGO)
https://linustechtips.com/topic/272015-build-help/#findComment-3690255
As others have noted the cpu is not compatible with the motherboard or memory.
For most users Windows Ultimate is a waste. Get Windows 8.1 (64-bit). It will have a much longer useful life.
2GB of DDR3-1066 is insufficient. 20GB is simply not achievable on Z97. Besides, in a z97 system one should be shopping for DDR3-1600MHz cl <= 9, or faster. In most general use systems 2x4GB is an optimal size.
The gpu are very dated. A GTX 970 outperforms the GTX 680 and typically is less expensive.
The 840 is a dated product, but 500GB is a great size for an ssd. The cost of a same capacity newer model should be less.
Caviar Blue is a good hdd, but 500GB is on the small side these days. Especially if one intends on storing movies, etc. The cost of a 1TB Blue is only about $10 more.
pcpartpicker.com is a great tool for putting together a build list.
If you want specific recommendations read Build Plan Thread Recommendations (Please read before posting) then start a new thread.
https://linustechtips.com/topic/272015-build-help/#findComment-3690825
