i have a i7-3820, i run a very mild overclock to 4.3GHz with a 1.3 Vcore, (multiplier is 43) RAM is 2133MHz, 11,11,11,27. it has been running stable for about a year. passed ~18 hours of Prime95 small FFT.
recently it has been crashing, blue screening.
i ran Prime95 again and it crashed within 30 minutes.
so have i degraded my CPU? <- Intel says the VID voltage range is 0.600-1.350v so i doubt it.
http://ark.intel.com/products/63698/Intel-Core-i7-3820-Processor-10M-Cache-up-to-3_80-GHz
during the winter the CPU temps where 60-65 degreese
now approaching the summer, they have raised to 70-75 degrees
could that be the problem?
PC : i7-3820 @ 4.3 GHz | Patriot Viper 3 Black Mamba 16 GB @ 2133MHz | Gigabyte GTX 670 SLI Windforce 3X | Gigabyte X79-UD5 | OCZ Vector 128 GB (Died) | WD Black 1TB |  | Asus Xonar DGX | Antch P280 | Asus PA238QR & NEC PA271w | LG 1440x900 Monitor | CM Storm Quickfire Pro (Cherry MX Brown) | Corsair M60 | Blue Snowball | Sennheiser HD 439 | IKEA Kitchen Table
https://linustechtips.com/topic/27175-oc-problem/
You may also have an aging motherboard, if you can test it in a friend's PC.
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
https://linustechtips.com/topic/27175-oc-problem/#findComment-345112
intel says max temp is 66.8c so...
Tcase isnt TJmax http://www.intel.com/support/processors/sb/cs-033342.htm
https://linustechtips.com/topic/27175-oc-problem/#findComment-345123
could that be the problems
hmm i was thinking something
it can also be your ram since you tweaked the BLCK
https://linustechtips.com/topic/27175-oc-problem/#findComment-345157
it is a Gigabyte X79-UD5 Rev 1
https://linustechtips.com/topic/27175-oc-problem/#findComment-345295
I mean the VRM/ PWM is degrading, not only the chip itself.
https://linustechtips.com/topic/27175-oc-problem/#findComment-345309
funny you mention UD5. the power phase on that is poop. so giggy went back to the board
and dev'd UP5 with digital. and...... swing and a miss...
whats the latest UEFI/BIOS you have now? should be F14.
have you tried to up the vCORE, yet? this maybe will verify stability..
or lower the multi and retest..
airdeano
https://linustechtips.com/topic/27175-oc-problem/#findComment-345908
F14? the highest version of Gigabyte's website is F13p
https://linustechtips.com/topic/27175-oc-problem/#findComment-346324
Have you tried running everything at stock to test for stability?
MOBO - Gigabyte GA-880GM-UD2H   CPU - AMD Phenom II X4 965BE @ 3.4GHz, Corsair A70   RAM - 2x Patriot G2 4GB DDR3 @ 1600 MHz + 2x Patriot Viper 3 4GB DDR3 @ 1600MHz   GPU - HIS Radeon HD 7950 IceQ X2 Turbo 3GB @ 950/1250 MHz   PSU - Corsair GS600 600 Watt   CASE - Fractal Design Arc Midi R2   KB - Logitech K340   MOUSE - Cyborg R.A.T. 7   MONITOR - eMachines E181HV
https://linustechtips.com/topic/27175-oc-problem/#findComment-346415
I am currently Using it at stock, it is stable. have done about 12 hrs of Prime95
https://linustechtips.com/topic/27175-oc-problem/#findComment-346466
