I am going to be sleeving my Corsair AX1200i when I get it, and the cables that I am going to sleeve are the 24 pin, 8 and 4 pin EPS, 8 and 6 pin PCI-E, any some other cables.... Which sleeving kits should I get? I will be individually sleeving it, and I would like to buy the sleeving from FrozenCPU. Is the corsair pre-sleeved kit worth it? I am limited to 2 days to build my PC, and to leak test my watercooling system. The colors I would like to get are white and red. I might sleeve the cables with both white and red...
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/
If I weren't lmited by time, what would be the best kit? I might want to sleeve it later on if I dont buy the Corsair kit.
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-344819
What do you mean by kit? If you want to go custom, you would have to buy the parts individually (ATX pin remover, sleeve, heatshrink, heatgun etc). Not sure if you can buy an actual all-in-one "kit".
Thats what I mean. I just call them kits because it's a shorter way to say it.... Sorry for the confusion.
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-344847
http://linustechtips.com/main/topic/18644-cable-sleeving-information-links-to-guides-and-videos/
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-344851
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-344853
Ah right - i'm with you. The 'best' is dependent upon what type of sleeving you want - paracord, MDPC, or something different. MDPC is widely considered to be the best of the best; however, you can only buy it from one person located in Germany (Nils) he's an awesome guy and i have dealt with him several times. Head over to his site here. It's a little hard to buy, but once you work it, it's pretty straight forward. In terms of tools, buy cheap, buy twice. Again, Nils @ MDPC, provides the best pin removers in my view, but they are expensive.
FrozenCPU, i believe, you can also buy similar pin removers; but i'm not sure how good in terms of quality they are as i have never had personal use with them. Heatshrink (if you want), again can be bought from MDPC, but can equally be sourced elswhere and probably more local to you.
EDIT: Just saw that Link above and just remembered that Lutro0 also provides the same tools; so it may be an idea to look at his shop. Here.
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-344855
Which size diameter should I go if I want to individually sleeve a cable? How about double braid like Linus did? Also, are the Bitspower Super Tight Weave decent? http://www.frozencpu.com/cat/l2/g35/c535/list/p1/SleevingHeatshrink-Bitspower_Super_Tight_Weave.html?id=DSUZzaeK&mv_pc=2720
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-344867
I'm pretty sure 1/16" should be alright; but don't quote me on that as i don't know for definite. If you want double braid, then get a large OD.
What color sleeving goes well with a red, white, and black themed pc build?
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-344891
red, white, and black XD
haha sorry had to
xD any other colors?
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-344902
I have MDPC sleeving too and I love it, and Nils' service is great! however it is a little pricy..
Lotro0 customs has his own shop with both paracord sleeving and sleeving similar to what Nils is offering. his site is, www.e22.biz
This guy has also made some pretty sweet sleeving tutorials on youtube! :)
(Comming soon)
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-344904
green is the contrasting colour to red :) should look good together XD
I dont know how that would look though.... Not a big fan of green overall...
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-345221
I would stick with the main three colours keep it nice a coordinated :D
If you were to pick 2 colors, which 2 would you pick? I would pick white with red.
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-345240
yes agreed :) it will look smooth
with my build though I'm going for a blue and orange type dealio :)
Edited by SirReallySam
PROFILEYEAH
What do people even put in these things?
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-345258
Alright. Thanks for your help guys, I will buy some Bitspower Super Tight sleeving, because it is sold in the same site as my watercooling stuff. I will then make some time then I will sleeve them. :)
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-345302
Ensourced does great work for a good price! look him up on facebook
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-346550
Light blue and white= sexayyy
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-346558
Though light blue doesnt go well with red... :/
Edit: For me it doesn't anyway.
https://linustechtips.com/topic/27150-best-psu-sleeving-kit/#findComment-348092
