it will put it's self to sleep every soo often even in the middle of a game and use it will also lose focus on the current window so it makes doing long paragraphs a pain in the ass.
if any one knows a fix for this plz tell me this could also be the wrong place for this but i don't know what it could be classed under.
main rig: http://uk.pcpartpicker.com/p/GFvH7P
next upgrades. h440 . 8320.  possible liquid cooling AIO
https://linustechtips.com/topic/27144-my-pc-has-sleeping-issues/
It must be so tired XD ok sorry that didn't help at all, just had to...
Seriously have you looked at the settings in your control panel called change battery settings on a laptop and standby on a desktop I think could be the same though... Have a look in there and see if there is an auto-sleep thing that can be disabled :)
PROFILEYEAH
What do people even put in these things?
https://linustechtips.com/topic/27144-my-pc-has-sleeping-issues/#findComment-344763
http://www.howtogeek.com/howto/9090/learning-windows-7-manage-power-settings/
You can try disabling sleep mode.
https://linustechtips.com/topic/27144-my-pc-has-sleeping-issues/#findComment-344783
gpu: 8800gt not oc
cpu: atholon x3 440 non oc
mobo: msi 760gm-p21 fx
ram: some kingston low profile ddr3 8gb
os:windows 7 ultimate 64 bit
hdd1: Samsung 1 tb
hdd2: hitatchi 160gb laptop drive
on second looks at the keyboard a sibling pushed down the sleep button so far it stayed deppressed but i am still having the issue of losing focus.
https://linustechtips.com/topic/27144-my-pc-has-sleeping-issues/#findComment-344813
