good day,
         i have been reading a lot about NAS, mainly because im planning on setting up one for personal use. it will be use as data center for all our media needs, mostly movies.
         my question is, would it be more ok if i will hard wire it? im worried that if i will stream it via our network, the movie will lag. i will use my samsung homesync as the main media console, the homesync will be then conected to the smart tv
 also what would you advice that i will use? RAID O, 1, 5 or 10?
thank you for the advance answer =)
https://linustechtips.com/topic/271434-nas-question-again/
If you have a decent router it will be fine both ways, I tuck mine in a closet and use a AC-68 Asus adapter and it NEVER stutters.
thanks for the quick reply,,
i just want to add, what configuration do you advice?
RAID 0? is this also same with yours?
https://linustechtips.com/topic/271434-nas-question-again/#findComment-3682726
Personally, I would suggest RAID 5/6. RAID 6 is preferable due to the write hole issue with RAID 5, but both are better than RAID 0 (which is effectively negative redundancy).
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/271434-nas-question-again/#findComment-3682961
I would hardline it if I were you unless you have a bomb router. Also, I would use Raid 5 for up to 5 total disks and Raid 6 after that for the reasons stated above.
Thank you all for the reply..
Sir as i understand from your post, i will use both raid 5 and 6? Combination of both?
I want more of security. One of my portable hard dive failed and all of my 1terabite of movies gone..
https://linustechtips.com/topic/271434-nas-question-again/#findComment-3683275
You will use one or the other depending on how many drives you're willing to sacrifice to parity. If security is your concern, RAID 6 is safer between the two.
https://linustechtips.com/topic/271434-nas-question-again/#findComment-3683287
My plan is to get 4bay NAS. I will do further reading about raid6. Im still new to this and im willing to learn :)
https://linustechtips.com/topic/271434-nas-question-again/#findComment-3683359
Synology offers many different RAID levels, depending on which product you choose. I doubt RAID 0 will be the default on any of their devices, though...
[Main rig "ToXxXiC":]
CPU: Intel Core i7-4790K | MB: ASUS Maximus VII Formula | RAM: G.Skill TridentX 32GB 2400MHz (DDR-3) | GPU: EVGA GTX980 Hydro Copper | Storage: Samsung 850 Pro 256GB SSD + Samsung 850 EVO 1TB SSD (+NAS) | Sound: OnBoard | PSU: XFX Black Edition Pro 1050W 80+ Gold | Case: Cooler Master Cosmos II | Cooling: Full Custom Watercooling Loop (CPU+GPU+MB) | OS: Windows 7 Professional (64-Bit)
https://linustechtips.com/topic/271434-nas-question-again/#findComment-3683880
