GTX 970 reference cooler temps
Solved by Mick Naughty,
If they are anything like the last gen, in a single card config with great airflow, you should be 5-8 degrees Celsius higher.
PopsicleHustler ·
Posted in Audio2 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory10 -
11
play_circle_filled
Latest From ShortCircuit:
