DNS problems. Please help!
Solved by dantayy,
According to this, your DNS server is your own system or something? lol
DNS Servers . . . . . . . . . . . : 192.168.1.1
try using google's DNS servers.
Control Panel > Network and Internet > Network and sharing center > Click change adapter settings on the left > Right Click your connection > Properties > Scroll down to IPv4 Properties > Click on it and select properties > Change your DNS servers to: 8.8.8.8 as primary, and 8.8.4.4 as secondary.
After you are done, you should see this: https://www.flickr.com/photos/129974326@N05/16041246825/
