Question regarding possibly low PPD
Solved by tobben,
But I run this OC when I play games, and never once had it crashed. I even pulled it down 15 MHz, and same thing is happening. I've had multi-hour gaming sessions at +170, so it seems strange it's crashing still at +155...
the load from a gaming session and the load put on your gpu from folding,
is entirely different. Gaming or stress testing stable doesn't guarantee
it will be folding stable. You are running a pretty aggressive overclock.
If your gpu was the problem, then surely you would see highly
irregular load and failing wu's. If you don't, well it's probably running
fine.
