Have you checked the pins on the underside of the CPU?
https://linustechtips.com/topic/270660-cpu-boot-problems/#findComment-3672534
Does the CPU actually function? Have you changed any other hardware during the CPU swap?
https://linustechtips.com/topic/270660-cpu-boot-problems/#findComment-3672611
We'll on your mobo are there any lights on before and after pressing the power on button. If so, send a pic
save the time and effort of that, it boots up both the same on the sempron and athlon just doesnt post on the athlon, i dont see any problem with the power supply.
https://linustechtips.com/topic/270660-cpu-boot-problems/#findComment-3672963
You don't get it do you.... If the mobi does not post, it gives out an error. Ode or two through lights...
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/270660-cpu-boot-problems/#findComment-3672977
Your CPU is dead. That is my what I consider to be an educated guess.
https://linustechtips.com/topic/270660-cpu-boot-problems/#findComment-3672980
