like every other guy on here....i need advice! help! XD
Solved by mansoor_,
From experience, CAD modelling is more gpu than cpu bound. Specifically, it does not benefit much from the multiple cores and threads. You may even find that a z97 cpu will perform just as well.
I would suggest downgrading to a z97 i7 and putting more budget into your gpu, quadro k4200. If you are going to be running engineering simulations and rendering too then
your build is good and you should keep the x99 cpu. Also if you will be running this pc all day, you may benefit from a higher efficiency psu.
source:http://www.pugetsystems.com/labs/articles/AutoDesk-AutoCAD-2014-Professional-GPU-Acceleration-504/
