High Temps! Help!
Go to solution Solved by TheDylinTech,
Good luck!
Thanks, I really did need it! I installed the 212 (took me a while but I did it) and I am very happy! 30 (idle), 40 (light tasks), 50-60 (Gaming/Rendering). Also I can now put on the window and switch off the fan next to my case. Don't you just love Australia!
Ok, this is getting ridiculous. I made a post a few days ago about temps on my CPU and eventually said that I would re-apply the thermal paste to the heatsink (which I have done).
Anyway, so what's happening is I'm getting around 40°c idle and up to 80°c load for my CPU. 50°c and 70°c for the GPU.
I'm using:
- Thermaltake S41 case with the stock 200mm fan & the 2 x 120mm fan's.
- i5 760 @ stock 2.8 Ghz
- Sapphire Tri-X R9 290
- Contac 21 Heatsink
- In Queensland, Australia however it is only about 20°c in my room at the moment
- (Any other specs are in my signature)
Now I don't know what to do... Should I go get a new heatsink... or what?!
Also!! Really big, while I am typing this I found in HWMonitor it says that my SYSFan is only running at arround 60RPM and max 585RPM?
The biggest bottleneck is the Aussie internet..
CPU: i5 4690k @ 3.5 | GPU: Sapphire Tri-X R9 290 | Motherboard: Gigabyte Z97X-SOC | RAM: 8GB DDR3 @ 1333 | Storage: 2TB HDD, 500GB HDD & 120GB SSD | CPU Cooling: Hyper 212 Evo x 2 fans | Case: ThermalTake S41
Display: 2 x 1080p Monitors | Keyboard: Logitech G510s | Mouse: DragonWar Phantom Battle Version | Mouse Pad: Logitech G240 | Audio: Logitech z506 Speakers & Audio Technica ATH-M50x | Misc: PS3, Iphone 5s & Ipad Air
https://linustechtips.com/topic/269984-high-temps-help/
Have you confirmed the temps in multiple software (Real Temp, Core temp). Also check the temps in BIOS.
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/269984-high-temps-help/#findComment-3664256
I have multiple programs such as Real Temp, Core Temp, Speccy, CPUID, SpeedFan. They all say the same thing.
https://linustechtips.com/topic/269984-high-temps-help/#findComment-3664281
I'm using:
70c is perfectly fine for the gpu. It's a freaking r9 290. The reference cards run 95c all the time. lol
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/269984-high-temps-help/#findComment-3664283
have you tried ramping your fans up to 80% or higher for a sustained amount of time to see if the temps drop.
Yeah, about a 2-3 drop.
https://linustechtips.com/topic/269984-high-temps-help/#findComment-3664286
Yep, I guess it's just the CPU. I'll be fitting on this week either the Noctua NH-U9B-SE2 or the Hyper 212x Evo.
https://linustechtips.com/topic/269984-high-temps-help/#findComment-3664291
what did your temps look like before you started having issues
Well, this is my new computer. I've been having these kind of issues since I built it last week, just haven't noticed. But, I should get a new heatsink this week.
https://linustechtips.com/topic/269984-high-temps-help/#findComment-3664297
What about the BIOS?
osu! profile
https://linustechtips.com/topic/269984-high-temps-help/#findComment-3664375
What section of the bios would that be in?
https://linustechtips.com/topic/269984-high-temps-help/#findComment-3664388
PC Health, Monitor or something similar. Just open all sections and look for it :P
osu! profile
https://linustechtips.com/topic/269984-high-temps-help/#findComment-3664408
I found it and it's saying the exact same thing 40-50 when idle. Look, it's some old crappy thermaltake heatsink. I'll get a new one tomorrow.
https://linustechtips.com/topic/269984-high-temps-help/#findComment-3664470
Guy's I got my Hyper 212 Evo today and have chucked a second fan on it. Should be installing it tonight, hopefully I get better temps.
https://linustechtips.com/topic/269984-high-temps-help/#findComment-3669746
Good luck!
My life is consumed by CS:GO, even though I'm not exceptionally good at it.
CPU: AMD A10-5800K | GPU: Gigabyte R9 270 2GB | RAM: 8GB 1333Mhz HyperX Blu | Storage: 120GB Samsung 850 EVO + 1TB WD Caviar Blue | Chassis: NZXT H230 | Mobo: Gigabyte GA-F2A88XM-HD3 | PSU: Corsair CX500 500W | Cooling: CM Hyper 212 EVO | OS: Windows 10
In order of priority: GTX 970 Strix, 2 good 1080p monitors, i5 4690k, MSI Z97 Gaming 5 LGA 1150, a job
https://linustechtips.com/topic/269984-high-temps-help/#findComment-3669767
Good luck!
https://linustechtips.com/topic/269984-high-temps-help/#findComment-3671687
