I need a little help. Tax season is coming around and i got around $2000-$3000 as a new Desktop budget. This is what i have figured out so far http://pcpartpicker.com/p/7N8gpg. I need to know if the power supply is going to be enough for when down the line i add in another gtx 970 strix. I have not built my own custom pc before but i have worked on them for many year and for the most part know what i am doing but i am unsure if the power supply is going to be good enough for a update or if i should use a 1000 watt power supply. I am also going to be switching the power supply to a fractal design power supply but didnt see that as a option on pc part picker. I am trying to go with a full white and black build Then i am going to put rgb lights in it so i can have it match my corsair k95 and corsair m65 when ever i decide to change the color
https://linustechtips.com/topic/269830-need-some-advice/
Everyone goes overkill with power supplies. A 650w PSU could power 2 GTX970s and a 5930k and have left-over room.
I'm not sure what you plan to do with your computer but honestly just go for a i7-4790k instead of the 5930k, unless you're going for 4 Graphics cards or are a serious creative content maker.
Please don't colour text by the way - impossible to read in night theme.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/269830-need-some-advice/#findComment-3662518
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($299.99 @ Amazon)
CPU Cooler: Corsair H110 94.0 CFM Liquid CPU Cooler  ($114.98 @ OutletPC)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard  ($199.99 @ SuperBiiz)
Memory: G.Skill Trident X Series 16GB (2 x 8GB) DDR3-2400 Memory  ($169.98 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($139.99 @ Amazon)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive  ($88.97 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Video Card (2-Way SLI)  ($329.99 @ Newegg)
Case: Corsair 760T Black ATX Full Tower Case  ($159.99 @ Micro Center)
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($149.99 @ NCIX US)
Case Fan: Corsair Air Series SP120 High Performance Edition (2-Pack) 62.7 CFM 120mm  Fans  ($27.98 @ OutletPC)
Total: $2011.84
Generated by PCPartPicker 2014-12-13 23:54 EST-0500
Couldnt open the link you posted because Facbook is blocked at my work, but this list is only 2000 dollars, so youll have another 1000 to spend on whatever you want
"If Everton were playing at the bottom of the garden, I'd pull the curtains." - Bill Shankly
https://linustechtips.com/topic/269830-need-some-advice/#findComment-3662551
