are they same size?
Solved by i_build_nanosuits,
yes those are both microATX form factor motherboards and they are the same size.h81 msi h81m-p33 v2 and ASUSTeK Computer INC. M4A78-AM (AM2)
Reason why i'm asking this is cause my MB is ASUSTeK Computer INC. M4A78-AM (AM2) and if it is same size it will fit in my old case!
my case is 5 years old
I hope that i don't need to upgrade my Case
