Need help improving my home network!
Solved by Pelop17,
I live in a 3 story house and gotz dem WLAN issues. My router (N-router with 2,4/5GHz capabilities) is located on the first floor (I know moving it up could fix the issue, but that can not be done) and I'm having trouble with the connection on the third floor (-77dBm on 2,4GHz and -84 on 5GHz). I'm thinking of setting up an AP at the second floor, but it would be alot of work and wouldn't look so pleasing. Are there other options I can look at?
Thanks in advance
get an access point repeater and put it on the 3rd floor so it can repeat your singnal and you can have wifi everywhere
