Need help overclocking my CPU
Go to solution Solved by EarthboundHero,
Final, for 24-hours if you want to be really safe. Incremental 1-hour. Do a big just maybe 500MHz see if that's good then go up 100MHz or down 100MHz. Not sure about voltage for that CPU. CPU, FPU, Cache. I think this is mostly right. Someone correct me.
This is my first PC build and I have never overclocked before, I watched the haswell overclocking guide by Linus, I still feel I need a bit more help though.
My specs are the following
 Corsair CX600M
 i7-4770k
16GB Kingston HyperX Blu 1600Mhz
ASUS Z97-PRO
ASUS GTX 770 DC2OC
1TB WD Blue
NH-D15 1 fan, (the second would not fit)
Some question I have are,
How long should I validate my final overclock?
How long should I validate my incremental steps?
What method should I take at overclocking (e.g quick and dirty first)?
Who much voltage is too much, when will the voltage start to bring the lifespan of the CPU down?
When I do validate what should I validate at the same time in AIDA64 (e.g CPU,FPU,Cache and GPU)?
And any recommendations you have :)
Thanks for the help, I am just a bit anxious I am going to kill my CPU, it was not cheap :)
EDIT: Also forgot to add, what increments in voltage should I go up and down?
Main PC: CPU: i7-4770k RAM: 16GB Kingston HyperX Blu SSD: Samsung 850 Pro 256GB HDD: 1TB WD Blue GPU: ASUS GeForce GTX 770 2GB PSU: Corsair CX600M Case: Bitfenix Shinobi OS: Windows 10 Pro 64-Bit
Laptop: ASUS N56VJ
https://linustechtips.com/topic/269285-need-help-overclocking-my-cpu/
just run prime95 for a couple of hours and if nothing happens, you should be good
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
From what I have heard with haswell CPU's it can override your max voltage set and ask for to much voltage
Laptop: ASUS N56VJ
1. Stress the overclock for around 12 hours.
2. An hour.
3. 4.5GHz @ 1.4 Volts for the first time, if your cpu hits the deck at that, take it down by 100MHz steps.
4. You'll know how much voltage is too much when the CPU shits itself. Giving it too much a few times is more then okay, but do not make a habit of it
| Intel i7 5820K @ 4.8GHz | G.Skill Ripjaws 4X4GB | X99 PRO | HoF 980 | Asus MX299Q | Sennheiser HD600 |
Never heard of that, but I'm an amd guy so I wouldn't know
Should I also test the GPU in the stress test, to give me a more realistic tempurature while gaming?
Laptop: ASUS N56VJ
You can, it won't hurt anything if you don't. If you really want to do a good stress test I recommend playing your most intensive game.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
Yeah I was thinking of playing some battlefield 4 after doing the last test
Laptop: ASUS N56VJ
No multiplayer though. You don't want to leave your team in case of a crash.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
24 hours for the final test sound quite long, how long would you think would be resnoably good but not over the top
Laptop: ASUS N56VJ
lol, yeah
Laptop: ASUS N56VJ
Maybe 3-4 at least. Then play an intensive game for a normal session length. Or you can run stability tests for just however long you normally play games for.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
OK 6 hours it is then I guess
Laptop: ASUS N56VJ
Oh Lord, Gaben
1.Make sure windows and drivers are up to date
2. Make sure BIOS is up to date
3. Get into BIOS
4.Turn off adaptive voltage
5. increase multiplier (from e.g 35 to 36)
5.Test the overclock (not a huge jump but  test anyway) Test using Intel Burn test, HWmoniter, CPU-Z and Prime95
6.Repeat, If you get blue screens, increase voltage by0.05
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
haha hours? I couldnt stand 1min lol :D If my clock is too  high prime95 says failed in the first 20 secs. I just use my computer normally and if it crashes i go down.
CPU: AMD FX 8350 | GPU: AMD R9 270 Windforce | MOBO: ASRock 990FX Extreme 3 | RAM: Kingston HyperX 8GB | Case: X Predator X1 |CPU COOLER: Hyper T4
NAZIS WILL RISE.
Started overclocking, currently stress testing at 4.2Ghz on 1.2v
By what Linus recommended doing I started at 4.6Ghz on 1.2v and went down by 1x until it could boot and was able to boot at 4.2Ghz
Laptop: ASUS N56VJ
I also used Aida64 not Prime95 as Linus recommend in this video
Laptop: ASUS N56VJ
4.2ghz at 1.2v was not stable and 4.1 at 1.2v was not, decided not to overclock it is not worth it at only gaining 100mhz, decided to just run at stock settings
Laptop: ASUS N56VJ
