im looking for an air filter for the front intake of my air 540 and i found this one  http://www.newegg.com/Product/Product.aspx?Item=N82E16811999240&cm_re=fan_filters-_-11-999-240-_-Product  was wondering if i run into any clearance issues with the plastic piece that covers the filter.
https://linustechtips.com/topic/269271-will-this-air-filter-fit/
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
https://linustechtips.com/topic/269271-will-this-air-filter-fit/#findComment-3656282
thanks for the suggestion with that link and a little searching i was able to find the company that made that filter package since i only need just the front filter.
https://linustechtips.com/topic/269271-will-this-air-filter-fit/#findComment-3662410
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/269271-will-this-air-filter-fit/#findComment-3662560
