So I installed my H110 into my Corsair 450D last night but I can't install both rad fans. I don't know what I should search for but I need a cable that can either split one fan header into two connectors or a 4 pin SATA power fan connector.
I'm not sure if it would be a good idea to have one fan connected to the motherboard and the other to the power supply however. One fan would be temperature controlled while the other would not correct?
Basically I'm not really sure what to do because the cables won't reach anywhere else. I could buy an extender and connect it to the very bottom of my board but I'm not sure what that cable would be called as well.
The fans are 140mm and have 4 pins.
Any suggestions?
https://linustechtips.com/topic/268800-h110-help/
Throw whatever fans you are using away, and buy noctua fans, with a noctua y-splitter.
I have 2 of those, and 2 corsair 140 purple led fans on my h110.
Dubs are better than subs
https://linustechtips.com/topic/268800-h110-help/#findComment-3650142
You can get a PWM Fan Splitter (4 Wire), Or you could go with a PWM fan extension, or if you where so inclined run them off of a fan controller.
Quantum Chaos: i7 6850K | 2x Strix 1080Ti SLI | MSI X99 SLI Krait | 32GB Corsair Vengeance LPX | Samsung 970 EVO 500GB | 3TB WD Red RAID 1
https://linustechtips.com/topic/268800-h110-help/#findComment-3650185
https://linustechtips.com/topic/268800-h110-help/#findComment-3650306
