Hey all, advanced warfare and bo2 are randomly freezing and won't let me exit therefore I have to restart my computer. I can play about 1-2 1/2 matched on advanced warfare and it freezes. I have kind of narrowed it down to steam as all other non steam games do not freeze. My connection is always a 4-5 bar so not my connection. If anyone knows any way to fix this please let me know.
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
https://linustechtips.com/topic/268428-game-randomly-freezing-help/
1. theres a few things that will help qos is one
http://www.howtogeek.com/75660/the-beginners-guide-to-qos-on-your-router/
2.go to a fibre optic internet with lightning fast speeds of  1gig it takes seconds to download a 1 gig file
playing online is overkill.no lag
http://www.golightspeed.com/
3.upgrade your system to handle online play by software
http://www.pgware.com/products/throttle/
4. change your page file to allow for larger load or use a sql server
http://tweakhound.com/xp/xptweaks/supertweaks5.htm
http://www.techradar.com/news/gaming/how-to-set-up-a-dedicated-games-server-1053429
good luck
