Well my astro a40's have pooped themselves, So I am looking at getting a new headset/headphones.
I am willing to spend about $200-300
Mainly playing csgo and other fps'
I had a few ideas of buying headphones and getting a modmic, is this a good idea?
Would rather the recommendations be from Australian websites!
Thanks in advance for any advice
Intel i5-4670K, Asus Maximus VII (z97), 16gb Kingston, Asus Gtx 780, Fractal Design Define Mini, 250Gb Samsung Evo, Corsair CS650M
        Yey dis meh Pc
https://linustechtips.com/topic/268061-gaming-headset-help/
Definitely. For the best sound quality, a modmic + headphones are the best way to go.
HD 598 + Modmic is a good combo :)
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/268061-gaming-headset-help/#findComment-3640153
Best plan is to get a modmic and higher end headphones. Or HyperX Clouds, but for your budget you can do much better.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/268061-gaming-headset-help/#findComment-3640156
What headphones would you recommend?
        Yey dis meh Pc
https://linustechtips.com/topic/268061-gaming-headset-help/#findComment-3640158
Headphone recommendation?
        Yey dis meh Pc
https://linustechtips.com/topic/268061-gaming-headset-help/#findComment-3640163
I would recommend the beyer 770 with a modmic, the sound quality of both the modmic and Beyers FAR outstrips that of the a40s(ive had two pairs of a40s and a pair of a30s)
If you want an open soundstage the 880s are supposed to be good
I took the advice of this video and goddamn its worth it, ive had loads of sets of gaming headsets and they were all terrible and overpriced compared to what i have now. Yes its one extra wire but tape the wires together and its well worth it.
https://linustechtips.com/topic/268061-gaming-headset-help/#findComment-3640853
Is the budget with a mic included?
https://linustechtips.com/topic/268061-gaming-headset-help/#findComment-3646116
