Get some cheaper ram. A seagate barracuda will save a few dollars. A cheaper motherboard would be good. You MAY be able to get a 970.
https://linustechtips.com/topic/267847-800-build/#findComment-3637122
What is your location?
Will You OC?
Will you Sli/Crossfire in the future?
I am from Croatia
I won't OC
Wont crossfire
I have bought prebuit PC few months ago and I decided to check what kind off PC I could have gotten for exactly same money if I did custom built.
Now I am asking you guys would you change something on it and whats your general opinion about it.
https://linustechtips.com/topic/267847-800-build/#findComment-3637152
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($229.77 @ OutletPC)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($84.99 @ Newegg)
Memory: Team Elite Plus 8GB (1 x 8GB) DDR3-1333 Memory  ($54.99 @ Newegg)
Case: Apex SK-393-C ATX Mid Tower Case  ($24.96 @ NCIX US)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($24.99 @ Newegg)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($14.98 @ OutletPC)
Total: $802.06
Generated by PCPartPicker 2014-12-10 19:16 EST-0500
https://linustechtips.com/topic/267847-800-build/#findComment-3637156
Total: $802.06
I want dual channel memory not 1x8gb.
I want 1TB HDD from WD, why 2x 1tb HDD?.
I don't want PNY GTX 780 that I never heard for.
Case doesn't support USB 3.0 and PSU most likely doesn't fit.
https://linustechtips.com/topic/267847-800-build/#findComment-3637192
I want dual channel memory not 1x8gb. I want WD brand 1tb HDD not some that I never heard for. I don't want PNY GTX 780 that I never heard for, case doesn't support usb 3.0 and psu most likley doesn't fit.
Psu will fit, hitachi is a good brand, 780 is a better video card, dual channel does not make much performance difference. Do you actually use usb 3?
https://linustechtips.com/topic/267847-800-build/#findComment-3637219
Edited my post a bit so its more clear.
I don't want to waste most of my money on GPU that performs bit better than r9 280x and cheaper motherboard. And yeah USB 3.0 is pretty important.
https://linustechtips.com/topic/267847-800-build/#findComment-3637236
Second hdd was a mistake, The idea was a MUCH faster video card.
Memory: Team Elite 8GB (2 x 4GB) DDR3-1333 Memory  ($57.99 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card  ($334.98 @ SuperBiiz)
Case: Raidmax Atlas ATX-295WB ATX Mid Tower Case  ($24.99 @ Newegg)
Total: $817.18
Generated by PCPartPicker 2014-12-10 19:27 EST-0500
Front usb 3.0
Gtx 970 (30% faster than 280x)
https://linustechtips.com/topic/267847-800-build/#findComment-3637253
