I`am starting my build but i`am not 100% sure if a Corsair CSM 550W 80+ Gold PSU is enough for this parts
AMD FX-8350
Cooler Master Hyper 212 EVO
MSI 970 GAMING ATX AM3+ Motherboard
Kingston Fury Black Series 8GB (2 x 4GB) 1600Mhz
Asus GeForce GTX 760 2GB DirectCU II GPU
PNY Optima 240GB SSD
https://linustechtips.com/topic/267647-how-much-watts-will-i-need/
Would probably be enough as the recommended for a 970 is 500 watt or something. If this was a fully AMD build it would be cutting it but it is probably gonna last. If you put it in pcpartpicker you get an estimated wattage and this gives you a nice indication of how close you are gonna be.
Edit: thought it was a 970 GPU but a 760 does a bit more still probably gonna be able to run it as it still consumes less then a AMD GPU. Can still try to put it in pcpartpicker.
Last Edit: estimated wattage is around 400 so you are gonna be fine. Get another SSD I read reviews and they say fast, but a lot of cons like it failing and problems with drivers. What is the price for that and what is the price for a MX100 or a Samsung 840?
That will be fine mate.
A decent 450W would just cut it, but that 550W Gold psu will have no problem powering that setup.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
Get a corsair cx500m it is semi-modular
Buy my yoga 2 pro!  http://linustechtips.com/main/classifieds/item/2711-lenovo-yoga-2-pro-i7-4510u-8gb-ram-4k-btc-accepted/
[spoiler=Trumps Wall
]AMD FX 8320 OC@ 4.4 GHZ GPUamd sapphire 7950RAM: 12GB CORSAIR XMS3 Psu: Corsair cx 500m CASE: Corsair 800d MOBO: Asrock 970 extreme 3 r2 Storage: 256GB mx100 SSD, 1TB WD Blue,1tb Seagate Barracuda in Raid 0, 750GB Seagate Baracude. Os Windows 7
CPU: AMD A-10 5800k RAM: 4GB DDR3 Storage:Random drives Mobo:msi SomthingCase: good question
I will try the PNY i can change it if its not stable.
Thank you :)
I all ready have the CSM 550W 80+ Gold
