The output is right but it says wrong in Code Forces   :(
#include <iostream>#include<math.h>using namespace std;int main(){int h1,min1,h2,min2;cin>>h1>>min1>>h2>>min2;if(h1==h2)    cout<<(24*60)-fabs(min1-min2);    else if (h1>h2)        cout<<((fabs((h1-24)+fabs(h2%12))*60))-fabs(min1-min2);    else if (h2>h1)        cout<<((h2-h1)*60)-fabs(min1-min2);}
https://linustechtips.com/topic/267513-help-in-c/
well, first of all, h1 will never be higher than h2, so you can get rid of that case, second, you don't need the math library, if h1==h2 then the answer would be m2-m1 and if h2>h1 the answer would be (h2-h1)*60+(m2-m1)
#include <iostream>using namespace std;void main(){int h1, m1, h2, m2;cin>>h1>>m1>>h2>>m2;cout<<(h2-h1)*60+(m2-m1);}
you can use this if you are too lazy to even use if clauses
this is assuming the go to bed and wake up time occur during the same day
The best way to measure the quality of a piece of code is "Oh F*** "s per line
https://linustechtips.com/topic/267513-help-in-c/#findComment-3633287
I thought about h1>h2 'cause it's 24-Hour format so h1 might be (22) and h2 (5) for example
https://linustechtips.com/topic/267513-help-in-c/#findComment-3633317
