Can somebody suggest me what kind of psu i shood buy and what will be enough power to this system (corsair)
+ 2X gigabyte gtx 970 4gb soc G1 Gaming
+ 4790k
+ 2x ssd corsair 240gb
+ hdd wd black 1Tb
+ corsair h100i
+ asus rog front base
+ 16 ram corsair vengeance
 tnx  ;-)
https://linustechtips.com/topic/267470-help/
good quality 750w will power it with a mile of headroom for overclocking.
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/267470-help/#findComment-3632552
Corsair RM750 or AX760i
Oww not RM series; it's decent and all but corsair cheaped out on the capacitors and didn't use the normal higher grade ones that they use to so it can potentially have problems with longevity.
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Quisque euismod suscipit est, non placerat turpis vestibulum sed. Phasellus et faucibus odio. Donec a nisi at purus porttitor ullamcorper auctor a nibh. Integer id neque a nisi laoreet ultrices id ac augue. Nulla facilisi. Nullam purus elit, dictum quis euismod vitae, mollis non dui. Morbi vehicula neque eu mattis bibendum. Curabitur sed odio tortor. Sed euismod mi in diam volutpat, vitae convallis ipsum mattis. Praesent eleifend faucibus pulvinar. Interdum et malesuada fames ac ante ipsum primis in faucibus. Vestibulum velit nunc, fermentum a libero a, venenatis tempus lectus.
https://linustechtips.com/topic/267470-help/#findComment-3632581
i do i canculate this?
there is any formula
just the 2 gtx take together 1100W
how it's work?
750w PSU is enough what ever you used is way off
I heard the higher wattage ones are more reliable but I have no personal experience so I could be wrong
https://linustechtips.com/topic/267470-help/#findComment-3632593
Buy my yoga 2 pro!  http://linustechtips.com/main/classifieds/item/2711-lenovo-yoga-2-pro-i7-4510u-8gb-ram-4k-btc-accepted/
[spoiler=Trumps Wall
]AMD FX 8320 OC@ 4.4 GHZ GPUamd sapphire 7950RAM: 12GB CORSAIR XMS3 Psu: Corsair cx 500m CASE: Corsair 800d MOBO: Asrock 970 extreme 3 r2 Storage: 256GB mx100 SSD, 1TB WD Blue,1tb Seagate Barracuda in Raid 0, 750GB Seagate Baracude. Os Windows 7
CPU: AMD A-10 5800k RAM: 4GB DDR3 Storage:Random drives Mobo:msi SomthingCase: good question
https://linustechtips.com/topic/267470-help/#findComment-3632594
