New Build Help
Solved by Archangel1994,
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor (£167.50 @ Amazon UK)
Motherboard: MSI Z97-G55 SLI ATX LGA1150 Motherboard (£87.56 @ Scan.co.uk)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£35.94 @ Aria PC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card (£249.99 @ Ebuyer)
Case: Corsair Vengeance C70 (Black) ATX Mid Tower Case (£82.99 @ Amazon UK)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply (£62.71 @ Amazon UK)
Total: £686.69
Generated by PCPartPicker 2014-12-09 19:31 GMT+0000
Then this is a much stronger build. Save up a bit more money for a decent CPU cooler and you can OC that thing a good way. Recommend the Nepton 240m/280L, NH-D15, 212 EVO
