so i made a build not relizing my gpu deost have a vga post and i dont have a HD moniter and dont have money for one so what agre some good GPU's for gaming that have a VGA port
https://linustechtips.com/topic/266654-gpu-help/
You don't need a gpu with a vga port. Every port can convert to VGA win a $5 converter.
what is the converter like a what port to VGA? becasue the card i picked has a DVI-D a DVI-I and HDMI
https://linustechtips.com/topic/266654-gpu-help/#findComment-3622382
Not if they only have a DVI-D port, the 290 and 290X only has a DVI-D port which means you can't convert to VGA.
this is the card http://pcpartpicker.com/part/gigabyte-video-card-gvn750oc1gi can it be converted to VGA?
https://linustechtips.com/topic/266654-gpu-help/#findComment-3622589
