Help finding the right PSU
Solved by 79wjd,
500w+, 600w will probably be similarly priced though...so, 600w
If you might possibly upgrade to an R9 290 (or another top tier card in the future) then I'd go with a 600w for sure, and if you may go SLI/XFIRE in the future, then 750w+.
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases7 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning21
play_circle_filled
Latest From ShortCircuit:
