Crazy water cooling idea
Go to solution Solved by mrmonmon2,
Well you can ghetto it like this guy did
Could't get into bios. Took out the cmos battery and it booted
Sounds like you didn't have some voltages set up correctly or possibly a memory issue? Anyway, always overclock in small incriments and run a stress test like AIDA 64 or IBT AVX, Prime95 has been known to over volt intel chips so you should look into that before using that as a stress test.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
